Steven I do not know about the "guru" bit. It's too cold here in England at the moment for the loin cloth.You sound as if you have what we called an "orange wheeled Super". The later ones of these had the minimec pump but only a single acting lift on draft control. You will also be missing the drop control knob on the front of the hydraulic lift. This would tie up the difference between the engine number and your Australian build date. Minimecs were fitted from engine number 1613500. Do not see any problem about the position of the number unless the tractor has had a new block and this was where the number was stamped by the person who fitted it. We used to have to replace blocks due to corrosion around the sleeve seal. I have a 1952 Fordson Major petrol/paraffin E1ADKN, the same shape as yours. That plus 2 TE20's, an Allis B, two Nuffield 4/65's and a Claas Matador combine plus a collection of ploughs cultivators and planters. I used to be a Ford Master Service tech, then managed a Ford Dealership. Fordson Majors and Nuffields are my favorites though. Brings back my youth :) regards Brian please feel free to E-Mail if I can help.
