Fordson Tractors Discussion Forum
3PL Fordson Power Major is stuck !
Craig milne
11-29-2007 01:30:14
Hi,is there anybody that may be able to tell me why the 3PL on my Fordson Power Major will not lift?? I have added 20lts of the correct oil,but I have no luck lifting my slasher.
I`m requiring some help to overcome this problem,preferrably and hopefully easily and cheaply.PTO working fine and no slop/play in the shaft.
Await advice and thanks in advance for the help.
Kind regards,
Craig.
DAO
11-29-2007 02:50:32
 Re: 3PL Fordson Power Major is stuck ! in reply to Craig milne, 11-29-2007 01:30:14
IF YOU HAVE GOOD OIL LEVEL AND YOUR SHAFT IS TURNING,TRY TO GET REACTION BY MOVING DRAFT AND POSITION CONTROL LEVER.IF THAT DOES'NT WORK PULL YOUR SELECTOR LEVER AND SEE IF YOU GET FLOW THROUGH YOUR REMOTE.IF NOT,THEN PULL LIFT COVER ASSEMBLY,AND ROLL ENGINE OVER TO SEE IF YOU HAVE FLOW FROM YOUR SUPPLY TUBE.IF YOU DO THE PROBLEM IS IN YOUR VALVE BLOCK,IF NOT YOUR PUMP HAS A SHEARED KEY OR IS BADLY WORN.GOOD LUCK.
