Fordson Tractors Discussion Forum
Fordson Dexta Wiring Conversion
Walter Allen
10-08-2007 08:15:20
In the effort to rewire the Fordson Dexta. I have run into a delima. I found the wiring diagram in the on line repair manuel, and it shows where all the wires lead. But I need to re do the wiring because I need to fit the altinator as a replacement for the generator. Questions I have are. Do I need to change out from positive ground to negative ground? If I do is there a rewiring diagram available? If not the question would be can you hook the altinator in as the generator was? Right now I"m afraid of burning up the wiring if done wrong. Thanks in advance for any help. Walt Allen
(sonny)
10-09-2007 15:58:22
 Re: Fordson Dexta Wiring Conversion in reply to Walter Allen, 10-08-2007 08:15:20
go to harry-ferguson discussion forum; go to 9-22-07 rusty nut, page 5 9-29-07 rusty nut " 3 10-2-07 rusty nut " 2 hope this helps
Walter Allen
10-10-2007 05:34:57
 Re: Fordson Dexta Wiring Conversion in reply to (sonny), 10-09-2007 15:58:22
Sonny: Just as soon as things slow down here a little I will do just as you said. Thanks for all you have done. Walt
(sonny)
10-08-2007 18:55:08
all alternators that i have seen are negative ground..rewire diagram is available on line, i don't remember where, i saw it. ferguson i think.
