Fordson Tractors Discussion Forum
What Model Fordson do I have
KevinT
10-07-2007 19:19:56
Just picked up what I was told was a 46 Super Major. Based on my research that is not possible. Block Serial numbers are S752994, which I believe the "S" means the diesel engine was replaced. This number was located over the injectro pump under teh #1 injector. It has a Simms injector pump and the casting code on the tranny is A31X and the rear Dif is A27X. I think these equal a Jan 55 production date. Therefore, it is probably a New Major. Is that correct?
stevenbr549
12-22-2007 19:51:20
 Re: What Model Fordson do I have in reply to KevinT, 10-07-2007 19:19:56
I"m having the same trouble with my tractor. I know it"s a Super Major or Ford 5000, but I haven"t figured out which yet. The # on my block is S204111, which doesn"t match up to any serial numbers I"ve found. If you figure yours out, please let me know.
Mike Farmer
12-03-2007 13:46:14
That No appears to be April 1964 (not 1946) MTF
tiresntracks
10-07-2007 21:56:33
You're right, those parts were cast in Jan. '55. The tractor was probably put together shortly after that. I think that the S prefix on the engine means that it was a power unit for something besides a Fordson tractor, so the engine was replaced at some time.
