Fordson Tractors Discussion Forum
Super Major Clutch Issues
Scrambler
07-13-2007 07:27:07
I have a 1962 Super Major Diesel with out live power, I am having clutch problems.
A year ago I had problems with it not engaging. I took it to a shop and they cleaned the brakes and did some adjusting and it has worked until now > What do the brakes have to do with the clutch?
> The release point for the clutch has moved around and is now close to the bottom of the pattern > Can the release point be adjusted like on a car or truck? If so how
> The clutch does not want to disengage very well, if you work with it and get it in gear it will stop and start the movement of the tractor just fine.
> If you shift quickly you can change gears when disengaged.
Any suggestion would be appreciated
Thanks in advance
Mike
dwol
07-16-2007 19:08:29
 Re: Super Major Clutch Issues in reply to Scrambler, 07-13-2007 07:27:07
Not sure about the single stage clutch, but on the dual there is no way to adjust without spliting the tractor. Once split you can adjust the fingers on the pressure plate. They each have a screw which goes in for more pedal or out for less pedal. It is a real guessing game, and once you have the tractor appart you might as well replace the clutch and bearrings for new so as to not have to do it again.
good luck
woodache
07-13-2007 08:01:30
 The Clutch is Re: Super Major Clutch Issues in reply to Scrambler, 07-13-2007 07:27:07
The Clutch is gone! Prepare to break the tractor and replace! Sounds like the rivets are loose. You sure you only have a single clutch? Single clutch is an easy job. But if you do have a duplex clutch expect this to be expensive job. Very few Supers had a single clutch!
Scrambler
07-13-2007 14:25:08
 Re: The Clutch is Re: Super Major Clutch Issues in reply to woodache, 07-13-2007 08:01:30
Yes, it is a single stage cluch, have had that confirmed by more than one mechanic.
Thaks for your reply
Mike
Scrambler
07-13-2007 14:22:45
I guess you are saying there is no adjustment on a Ford Super Major clutch?
woodache
07-14-2007 06:24:22
 Adjustment Re: The Clutch is Re: Super Major Clutch Issues in reply to Scrambler, 07-13-2007 14:22:45
The upper link rod has a threaded fork that can be turned either way to adjust foot pedal throw.
