Fordson Tractors Discussion Forum
6 volt weak spark
Scott Essary
06-03-2007 11:40:23
Hey Guy,s, I need your help.
Mid 50,s ford. Won,t start. Spark at coil seems weak and spark at plug is worse. Replaced coil and battery no change. Turns over ok but no start. Any thoughts.Don,t really get the 6 volt positive ground systems.
Thanks Scott
dwol
06-06-2007 14:04:29
 Re: 6 volt weak spark in reply to Scott Essary, 06-03-2007 11:40:23
I would suggest you post this on the for 9n,2,8n forum. You will get lots of ideas.
LenND
06-03-2007 13:53:32
You can try a different battery or 12 volt but that isn't your problem. Someplace in your system your losing the spark maybe you need new wiring or coil. Higher volts will help but sooner or later your problem will show up again.
LenND
06-03-2007 13:53:30
delta bob
06-03-2007 12:07:27
You may want to try an 8 volt battery or change it over to 12 volt.
