Re: Ffilling the crankcase and transmission
Theman
02-14-2000 11:46:12
The two are separate. There is a plate inside the transmission case not very far ahead of the gearshift lever that divides the two cavities. Add engine oil up by the fan belt on the left side and add gear oil at the plug below the gearshift lever. The large and small plugs on the bottom of the tractor just behind where the engine block and transmission are joined are used when changing engine oil. Remove them both since the large plug drains a sediment area. You may even find condensate in there so both should be drained at the same time.
My Fordson is also a '23 model. It is serial no. 283322. How close to this is your Dad's?
