Fordson Tractors Discussion Forum
Fordson serial number
ruberwheels
04-05-2007 12:18:39
Can any one help me identify my mager the serial number is 530E7698 this is on the block below number one injecter.
the casting number is K22B.
It has the number spe 4a755527 on the injector pump.
I hope somone can help.
ruberwheels
04-09-2007 10:46:04
 Re: Fordson serial number in reply to ruberwheels, 04-05-2007 12:18:39
many thank"s for that.
I think the engine was ment for one of the 500 serise little lorrys but not sure. I have seen this on the forum somwhare.
Justin Kelly Draney
04-07-2007 12:34:26
Where do you find the serial numbers on these Fordson Tractors?
tiresntracks
04-07-2007 22:33:44
 Re: Fordson serial number in reply to Justin Kelly Draney, 04-07-2007 12:34:26
On the older Majors it's stamped on the flange behind the starter. From about 1955 (I think) on, they were stamped on the block under the no. 1 injector. They are also stamped on the plate on the front of the firewall.
tiresntracks
04-05-2007 22:37:48
The serial number on the engine doesn't look like a tractor one. The engine must have been replaced at some time. The casting code means Aug. 22, 1958. Look for casting codes on other parts to give you a better idea when the rest of the tractor was made.
