Fordson Tractors Discussion Forum
Fordson with Howard transmission ? Help Wanted
PaulN (WA)
03-29-2007 00:42:22
The transmission is located FORWARD of the main transmission adds about 5 inches to length of the tractor. It says HOWARD in large cast letters on the top of the case. The shifter is on the left hand side of the unit. It is not an Everett or a Sherman. The grill/bonnet/engine looks the same as the Fordson Major, 4cyl dsl, Simms pump, starter, fuel pump and filters same. Has a HI/LO shift like the Major. Throttle control on top of console like an N tractor. The position control moves fore and aft, looks like it might have a draft control lever and there are a couple more knobs/valves under the front part of the seat. It does not have drum brakes. Brakes are close coupled to the tranny(sealed?). Can anyone identify? No PICS yet. Thanks in advance. PaulN
David in Wales
04-03-2007 08:04:26
 Re: Fordson with Howard transmission ? Help Wanted in reply to PaulN (WA), 03-29-2007 00:42:22
Hi;
I worked for Dowdeswell ploughs who took over Howard Rotavators in England. Howard made several versions of the reduction box, originally for use at ultra low speeds for a Fordson Major rotary drainage unit.
Later they made different gear ratio'd sandwich boxes for Fordson Majors, Ford 4000 & 5000, and MF 100 series tractors. Two different ratios were available according to what the tractor would be used for. Most went for vegetable harvesting areas where they needed slower speeds for planting & harvesting.
NO PARTS are available today in England. But the sandwich boxes are high sought after for plowing competition work.
Cheers David
paul newbury
05-15-2007 13:39:57
 Re: Fordson with Howard transmission ? Help Wanted in reply to David in Wales, 04-03-2007 08:04:26
Hi - David in Wales.
I'm still looking for more information on the Howard transmission in my Super Major. The Howards that were installed in the N Series tractors are very fragile and no parts are available here (USA). Probably broken because they were mis-used (like pulling stumps). I'm wondering if the ones in the Super Majors are also fragile. How is this trans used for pulling? Is it used for tractor pull competition? Have you any clue as to where I may find documentation/specs for this transmission?
Regards,
Paul Newbury
Snohomish, WA. USA
PaulN (WA)
03-29-2007 13:29:45
Thanks for the info. What year might an early Super Major be? Was the Howard sold as an option? What is the reduction on this transmission? I assume it does not affect PTO speed. Is that correct? The tractor is in western Washington.
Thanks again PaulN
WBinPA
03-29-2007 17:56:57
 Re: Fordson with Howard transmission ? Help Wanted in reply to PaulN (WA), 03-29-2007 13:29:45
I bought a tractor with a Howard unit on it also. I found some literature which indicated a gear reduction of 3:1. I don't believe it affected the PTO. Mine was on a Ford 841.
woodache
03-29-2007 07:32:09
 Here is what Re: Fordson with Howard transmission in reply to PaulN (WA), 03-29-2007 00:42:22
Here is what it is an early Super Major with Howard Roto-tiller gear trans in it.
jeff wenner
03-29-2007 09:02:55
 Re: Here is what Re: Fordson with Howard transmiss in reply to woodache, 03-29-2007 07:32:09
WHERE?
