Fordson Tractors Discussion Forum
MODEL F FRONT AXLE QUESTION
NICK D
03-27-2007 09:09:55
I have a Fordson F tractor with a Serial #729332, which seems to make this tractor a 1927. The tractor also has the bowed or radius style front axle, which is like my 1929 Irish. Did the model F's have this axle also at the end of the production run? This serial number is only 10,000 from the first Irish. thanks.
Butch Howe
03-27-2007 20:54:17
 Re: MODEL F FRONT AXLE QUESTION in reply to NICK D, 03-27-2007 09:09:55
Nick, I have never seen a Fordson F that came with the Irish style axle. The Irish front cover is designed to accept this axle although it will fit in an F. I had a parts tractor #743005 which I parted out. It is the latest F that I've ever seen. (The Welker boys in PA have the engine). It had the F axle. I did have an F once with an Irish axle in it. It was intentional tho as it was put in upside down to get more clearance in the front. You never know what you'll see in a Fordson!
NICK D
03-28-2007 03:24:12
 Re: MODEL F FRONT AXLE QUESTION in reply to Butch Howe, 03-27-2007 20:54:17
Thanks Butch. It appears I have hybrid. I picked up this tractor last year, but never noticed the axle until now. It also has the heavy cast front wheels and spade lugs on the rears. I'll call it an FN.
richard in nz
03-30-2007 03:52:49
 Re: MODEL F FRONT AXLE QUESTION in reply to NICK D, 03-28-2007 03:24:12
Sounds interesting, does your tractor have a Cork built backend? Is it possible that you could have a Cork tractor with a Detroit engine?Lots of things can happen over 80 years.
