Fordson Tractors Discussion Forum
Fordson Power Major serial #'s
Harl
03-04-2007 12:29:02
I am looking to buy a Fordson Power Major but need some claification on serial numbers. On the right front (of engine block) is stamped 1585143 indicating a 1961 Power Major. But there is also stamped (near the same location)another number--e1addn-6056 13167?? would this be an e1a diesel designation??
morningwood
03-04-2007 18:01:54
 Re: Fordson Power Major serial #'s in reply to Harl, 03-04-2007 12:29:02
That is probably just the part number for the engine block possibly. My parts manual is out in the barn for me to double check. E1A specifies that it is a "new" major and not a older E27N major.
All of the bigger parts on the tractor generally have part numbers cast into them.
I have a diesel power major also, great machine for its time.
Scott
harl
03-04-2007 19:31:33
 Re: Fordson Power Major serial #'s in reply to morningwood, 03-04-2007 18:01:54
Thanks for the heads up. I am a newcomer to the Fordson Majors and still a little confused as to how to determine year & model. I understand production of the 'Power' Major began with serial #1583906 in 1961. However production of the 'Super' Major began in Oct 1960 with serial #1575886. Did the the two models overlap each other for a few years?? If so, how can I confirm year and model??
Harl
tiresntracks
03-04-2007 22:08:09
 Re: Fordson Power Major serial #'s in reply to harl, 03-04-2007 19:31:33
The information that I have says the Power Major began production in 1959 with serial# 1481091. The Super Major came out in Oct. 1960 with serial# 1575886. The different versions of the Major didn't overlap, they were upgrades on the previous one. I hope this helps.
Harl
03-05-2007 06:16:38
 Re: Fordson Power Major serial #'s in reply to tiresntracks, 03-04-2007 22:08:09
Thanks for the info. This will help to get me pointed in the right direction.
Harl
