Fordson Tractors Discussion Forum
Fordson industrial 6cyl diesel
Rob Marano
02-09-2007 12:23:40
Can someone explain the procedure to set the tappets on this engine?
Also clearences.
I've just had the injectors overhauled and would like to do the tappets myself.
Regards, Rob
Illar Pruel
04-08-2007 10:02:07
 Re: Fordson industrial 6cyl diesel in reply to Rob Marano, 02-09-2007 12:23:40
I have also 6cyl.engine, but it`s not original on this Fordson and i had a problem with valves as well. I just canged valves, springs, guides etc. Clearances: book says, that first set the clearances: in - 0,381mm (0,015")
out-0,305 mm (0,012") and after start when engine is hot you should reset valves again with same size. I have some books for P6TA engines and also Fordson 6cyl.engine and i am just overhauling my engine right now.
