Fordson Tractors Discussion Forum
major compression
wayde
12-24-2006 18:05:20
I need to know what the compression is on a major thank wayde
JD dozer mike
01-05-2007 17:41:30
 Re: major compression.IT SAYS in reply to wayde, 12-24-2006 18:05:20
Just got my IT manual,for major and power major,compression, cranking pounds 365.
that is from the IT manual.
wayde
01-05-2007 20:07:25
 Re: major compression.IT SAYS in reply to JD dozer mike, 01-05-2007 17:41:30
Thank again JD. I'll go back to timing and check it again,I've been on other job,but hope to get back on it soon. thank. wayde
JD dozer mike
12-30-2006 07:19:19
 Re: major compression in reply to wayde, 12-24-2006 18:05:20
check this link:
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=rrtips&th=11776
R Wooley
12-29-2006 19:32:10
I would suspect you have air in fuel lines.
my limit experience with diesels turning over with the starter around 200rpm you should get 300 to 375 PSI on each cylinder (you don't want more than about 30 psi diferance between cylinders) I have an old ford manual that indicates these values also a kubota manual states the same.
wayde
12-29-2006 17:54:32
Thanks again JD. That might be ok for a gas but I have a diesel. I've 370-380 lbs adv.but can't make it run on diesel.Injectors seem to be working good,change injector pump,check timing twice.I know that Ford 172 diesel are about 550 lbs.
wayde
12-28-2006 16:56:38
 Re: major compression in reply to JD dozer mike, 12-27-2006 13:04:16
Thanks JD. Could you tell me what that converse to in lbs. thanks again.
JD dozer mike
12-28-2006 18:54:14
 Re: major compression in reply to wayde, 12-28-2006 16:56:38
Nope not that smart.
JD dozer mike
12-29-2006 13:33:42
 Re: major compression in reply to JD dozer mike, 12-28-2006 18:54:14
Ok well, i messed around with some math last night (couldnt sleep) If my theory is correct(and it may not be) ... I took the square surface area of the piston, circumferance 3.934in X pi 3.14 , and multiply by the compression ratio 16.1 and came up with 195-195 psi.
THIS IS JUST A GUESS!!
IF ANYONE KNOWS HOW TO FIGURE THIS FOR SURE PLEASE CONTACT ME.
