Fordson Tractors Discussion Forum
Comp Release Lever removel Re:Ford industrial 220
woodache
12-11-2006 22:44:37
The lever can be removed by taking out the center bolt the lever may be stuck but a little wiggling till it losens and it will just slide forward off. That hole can be plugged by a variety of means if not removing the valve cover just put a good fitting cork in it. If you want to remove the valve cover use a couple of body washers with a bolt through them to seal the hole.
