Fordson Tractors Discussion Forum
Govener
Smiley Keith
12-04-2006 16:09:16
My major seems to idle at to high rpm what may be the problem and also seems to rev to high Thanks Keith
morningwood
12-07-2006 08:15:02
 Re: Govener in reply to Smiley Keith, 12-04-2006 16:09:16
Smiley,
Too me it sounds like the diaphram on the back of your injection pump has gone bad. If you take the tubes out of the back of the pump and put your fingers over the wholes you should be able to pull the stop button and feel some resistance. If not you need to have the diaphram replaced. You can do this yourself but I personally would take it to a injection shop to have done.
You might also wanna make sure your air cleaner is clear also. The sometimes get plugged up with a oil / grease mixture over the years.
Scott
