Fordson Tractors Discussion Forum
Seized Clutch and Lift
Martinloftus
11-18-2006 15:48:13
hi all.
I've a 957E that I took out of the shed today for the first time in 11 years. It hadn't been started in that time. Got it going after about an hour and a little easy start. I've a feeling the rings will need replacing any how (comments more than welcome).
Anyway, to my question. When the tractor was put away, both the clutch and lift were working fine. Depressing the clutch now has no effect. The drive train runs to the pto and can't be clutched. I forced it into gear today just to get her moving. Also the lift arms don't operate when the handle is pulled up.
If anyone has any suggestions, I'd appreciate them as I don't want to split the tractor to get at the clutch
Martin
JD dozer mike
12-24-2006 18:38:18
 Re: Seized Clutch and Lift in reply to Martinloftus, 11-18-2006 15:48:13
THIS CAN BE DANGEROUS!!
Start the tractor in the highest gear it has and drive it around with the clutch pedal depressed, varie the trottle to stress the clutch, it may break loose. Be carefull!!!
