Fordson Tractors Discussion Forum
Fordson F Valve Guide
Streeter
10-21-2006 07:07:22
I have been slowling trying to free up engine by allowing it to soak, and was trying to remove the valves from the worst cylinder when I thought the valve freed up to remove, but found half the valve guide came up with the valve. I trie to remove guide from valve stem, but it crumbled. Can this be built up with JB weld and remachined, or is my block shot?
Bob
10-21-2006 12:24:07
 Re: Fordson F Valve Guide in reply to Streeter, 10-21-2006 07:07:22
KO LEE, and others have generic guides that will fit almost anything.
Almost certainly, a good engine machine shop can bore out the block, and press in a ne guide.
Aussie Frank
10-23-2006 00:15:02
 Re: Fordson F Valve Guide in reply to Bob, 10-21-2006 12:24:07
Hi,
What has happened is a common problem. Just punch the rest of the guide out and fit a new one. Your block will not be damaged in any way. As far as I know www.old20.com should stock them as well as Fordson House. Who you choose is probably determined by which side of the pond you live on.
Regards, Frank.
