Fordson Tractors Discussion Forum
Re: Power Major engine knock
Majorman
10-18-2006 08:32:38
Its a bit hard to diagnose from your post. A knock from an injector would give a slight misfire and a possible puff of white or black smoke. You would also be able to feel the heavy pulse in the pipe.
As you do not mention any of these things I would go with the diagnosis given, a mechanical knock from either, big end, damaged piston, little end or even, in the worst case, broken crankshaft.
