Fordson Tractors Discussion Forum
Super Dexta Clutch??
Les in Missouri
08-31-2006 19:42:56
I'm a new owner to a 62 Dexta that is real nice shape with 1,800 hours. Periodically when you press the clutch it still pulls till you hit the brakes. Other times it operates just fine. Same thing when putting it in gear. Grind/Grind work the clutch and then it pops in gear fine.
Seems like everything is adjust right. Two stage for live poser works fine. Any ideas? Tractor was not used much last 5 years.
Majorman
08-31-2006 23:35:36
 Re: Super Dexta Clutch?? in reply to Les in Missouri, 08-31-2006 19:42:56
If it drags, it could be rust or even oil on the plates from standing about. It is strange that it will go in gear sometimes.
If the clutch was out of adjustment the problem should be there all the time.
I would be inclined to work her for a time and see what happens. Remember there is no syncromesh in that gearbox and you should wait for up to 3 secs. after putting the clutch down before it will go into gear cleanly.
Les In Missouri
09-01-2006 15:11:48
 Re: Super Dexta Clutch?? in reply to Majorman, 08-31-2006 23:35:36
Thanks for the input. I'll see if s little usage will cure the problem
