Fordson Tractors Discussion Forum
Timing Trouble ?
maine super 62
08-17-2006 20:09:29
you guys have probably answered this question a thousand times before , but i have to ask it, my super major is getting fuel , puffing white smoke , but not firing,and we have towed it to try and start it but with no success. we have also tried to time it and it's fuel pump (which has been rebuilt, and also has rebuilt injectors) so I'm assuming its timing, is there something that I'm missing?, any tricks that would help time it?...anything at all?
maine super 62
08-18-2006 09:34:37
 Re: Timing Trouble ? in reply to maine super 62, 08-17-2006 20:09:29
thanks for the info guys , I"ll try that
Majorman
08-18-2006 00:29:56
I would go with Miles.
Line the mark up in the sump window. Check whether the pump marks are lined up, then see if the clamp bolt on the front half of the coupling is above or below the drive shaft.
If its above, take the pump off and turn the engine 180 degrees until the sump mark come right and the clamp bolt is below the shaft, then refit the pump.
Miles
08-17-2006 21:15:55
I would guess that you have pump 180 degrees out...
Regards
