Fordson Tractors Discussion Forum
Tips for Pulling a 1953 Ford Major Diesel??
Larry in IL.
08-03-2006 22:33:04
My son is now 15 and we are wanting to fix up my Dads 1953 Ford Major for pulling, We need to stay with in 10% of stock RPM, Looking for some tips before we start?? We have what they call a 5500lb. class for 1939-1953 Our's is the last 1953 made. Thanks for any help! Larry & Cody
daveywavey
08-26-2006 11:49:11
 Re: Tips for Pulling a 1953 Ford Major Diesel?? in reply to Larry in IL., 08-03-2006 22:33:04
You guys might laugh, but my air intake rubber tube broke in half on my 62 FSM, and I was tired of that oil bath stuff so I bought some rubber tubing and connected an old K&N conical filter I had laying around to it. It breathes easier now, and throttle response is pretty much instantaneous, I found that out when mowing around a tree and a tree branch caught my throttle lever, and VROOOM instant full throttle...haha wasnt funny when it happened though...
BLUE HAULER
08-10-2006 09:24:39
If you want some black smoke and little more go. turn the fuel adj. screw on the back end of the SIMMS pump all the way out. the 15.5's are a good idea. The best power gain is to throw that old breather away and run a K&N type.
hahter
08-07-2006 17:00:12
My dad and I pull with a 53 Major diesel. All we did is gutted out the air filter cansiter and replaced it with a oiled foam filter. We just finished widing the 38 inch rims to fit 15.5 on the rims. We never run out of power and she hardly blows black smoke. These are some very tough little tractors. We took out the PTO, Hydralics, belt pulley, and hydralic pump. All of these are optional equipment and can be removed if you have factory cover plates, per the club you pull at rules. We have ours down to 4500 pds. You will need to fab some weight brackets for weights if you want to go into heavier weight class. Have fun and most of all, be safe.
Terry
