Fordson Tractors Discussion Forum
NEED HELP W/SUPER MAJOR REBUILD
rustymichaud
07-29-2006 20:42:45
I have a 61 super new crank and cam the problem is the cranks in and main gear I put the front plate on put the cam gears the cam gear that drives off the cranks is 1/4"further out then the crank the gears are back as far as thell go also the cam seems like it should move ahead a little but you cant with the front plate on any ideas thank you....
