Fordson Tractors Discussion Forum
smoky power major
Paul Ralph
07-08-2006 02:42:46
I have a smoky fordson power major , black on accelleration and white on decelleration. I have replaced the injectors and I"ve just had the fuel pump serviced but its still smoky. I have noticed however that there is one position on the throttle lever where it doesn"t smoke. In this position the governor operates and the exhaust is perfectly clear, but when its smoky the govenor doesn"t operate and I have to constantly adjust the throttle manually to get the right revs. I have checked the 2 pipes from the inlet manifold to the govenor diaphram and there are no leaks. Someone suggested low compression , but if it was that wouldn"t it be smoky all the time ? The governor diaphram was checked in the fuel pumps recent service. Any suggestions would be greatly appreciated.
Majorman
07-09-2006 23:38:46
 Re: smoky power major in reply to Paul Ralph, 07-08-2006 02:42:46
Try removing the pipe from the air cleaner to the manifold. Start up and see what happens. Don't over rev her. if the smoke clears you have a blocked aircleaner.
