Fordson Tractors Discussion Forum
year of fordson major diesel
scot green
07-06-2006 06:17:28
was told fmd was a 1958 when purchased my fordson.i would like to know correct year so i can get manuals to repair and restore the old beast.i found this #1341385 up by the battery and F11X on engine block and also on trans case by clutch. can anyone help me with these #s.
morninwgood
07-06-2006 09:11:29
 Re: year of fordson major diesel in reply to scot green, 07-06-2006 06:17:28
Looks like your tractor was made in 5/55 via the number on the engine. This would make it a fordson major. There are some sites that sell the repair / parts manuals. If you check ebay you generally can get them for the best price. I would stick with the ford re-prints of the manuals.
Here are a few web sites that can give you more info on your tractor
Link
Link
If you are looking for parts give bare-co or sparex a whirl, also google is your friend.
Thanks,
Scott
Majorman
07-06-2006 09:57:36
 Re: year of fordson major diesel in reply to morninwgood, 07-06-2006 09:11:29
Serial number and casting code give May 1955. Casting code gives May 11th.
scot green
07-06-2006 10:37:20
 Re: year of fordson major diesel in reply to Majorman, 07-06-2006 09:57:36
Thanks for the info on year and csting date.Time to rollup the sleeves and get at it.She is running perrty strong but appears to need the fuel tank drianed and cleaned.I changed fuel filter this past weekend ran strong for about 1 hour then quit.wasn"t getting fuel from the tank.should have known this would happen since its been sitting up for a few years.Thanks once again.
morningwood
07-06-2006 13:27:58
 Re: year of fordson major diesel in reply to scot green, 07-06-2006 10:37:20
There is filter screen on the petcock that comes out of the tank. When I pulled my petcock out a few months ago mine was plugged up pretty bad so that might be the reason you are not getting fuel.
Scott
