Fordson Tractors Discussion Forum
Top Rocker
James White
05-25-2006 10:37:45
In hooking up a box blade to my Dexta, do I use the top hole or bottom hole in the top rocker?
James White
05-27-2006 14:14:21
 Re: Top Rocker in reply to James White, 05-25-2006 10:37:45
Yes mine has a 3 hole rocker. Thanks for the info. Just wanted to make sure as the top hole in mine is broken out.
souNdguy
05-26-2006 22:55:31
If it has a similar toplink rocker as a ford 8n, 3 hole, the top hole is for light draft implements.. like spring tooth harrows.. and cultivators that need more mechanical advantage to trigger the draft sensing hyds.. high draft implements like plows and such use the lower hole.. your BB will be high draft..
This info can be found in ford N manuals.. probably in your fordson stuff too.. assuming it is based ont he ferguson system ( I think so ).
Soundguy
