Fordson Tractors Discussion Forum
Re: F Commutator Adjustment
Skyhawk Greg
05-18-2006 09:38:41
Found out what the tool is for, and thought I'd post it so that others would know. It is a tool that allows you to center the coverplate precisely around the shaft that rotates within the commutator. Since the coverplate is bolted to the block, it is possible that it can shift from one side to the other as you tighten it, and the end result is that the commutator body, when in place, will not be on the exact center of rotating shaft. The effects of not having the commutator on the rotating axis would probably include a minute shift of timing from cylinder to cylinder, and maybe even make the felt seal less effective.
