On a discussion forum, I like to be able to contribute to the knowledge pool of information. Unfortunately, the whole concept of having a Fordson Model F is new to me, so I must pay my dues, and respectfully ask for your help in trying to find the cause of a misfire condition in cylinder #2 of a 1923 Fordson.The short version is that cylinders #1, 3, and 4 purr smoothly, but #2 snaps and crackles constantly like it has a full race cam. No loud, and sudden bangs, but it is still disturbing never-the-less. Here is the long version: * It is being run on gasoline only * When switching coil positions within the coilbox, the problem stays with cylinder #2 * All of the coils have been set at about 1.3 amp draw * Hold down any combination of two coils with your finger, and the engine seems to run about the same rpm under each condition. However, whenever #2 is one of the cylinders that is running, the cackling is present. * Machined the old commutator to get rid of the waves. No difference. Installed a brand new cast iron commutator and roller. No difference. * Ran a new wire from the commutator to the coil box for #2. No difference. * Completely isolated the #2 coil with it's own voltage source, wire from the commutator, and high tension wire to the plug. No difference. * Changed the #2 plug wire. No difference. * Cleaned the #2 plug, and then swapped with #1. No difference. * Adjusted both the high and low adjustments to 1-1/4 turns outward on the Kingston carburetor. Waited until the tractor was warm, then set the high while at high speed, and the low while at low speed. They both ended up about where they started. No difference in the miss. * Sprayed starting fluid all around the intake manifold near cylinder #2. No change in rpm. No differences in any other way. * The cackling happens whether running off a battery or the magneto. * As the rpm increases, the cackling blends more into the overall tone of the exhaust, and there is only the occasional miss. * The aircleaner is a paper element. No water is used. * There is no muffler of any sort on this tractor. Just a straight exhaust pipe that exits behind the differential. I don't see how the piston rings could cause this, so the only thing left that I can think of is that carbon is on the exhaust valve of cylinder #2, or the exhaust spring may be weak. Thought about spraying a little water into the intake while running to break away the carbon. Has this happened to anybody else? Thank you, Greg
