Fordson Tractors Discussion Forum
need help with my hydraulic
Vidar Holmen
05-08-2006 15:16:47
Hi Major man,I have a fordson diesel major 1955. I still have problems with my hydraulic. I have try to take the valve chest of and change all the o-rings. I still need full power to lift it up.
while the lift is up it dont fall down so the thigtening must be ok.
is there some o-ring in the pump?
where can I locate this o-ring?
I realy need help please.
Vidar
Majorman
05-15-2006 23:00:09
 Re: need help with my hydraulic in reply to Vidar Holmen, 05-08-2006 15:16:47
Sorry I have not been around to answer your query. I have had a few personal problems.
You will have either "O" rings failed in the pump or possibly a worn out pump. You can get to the pump in one of two ways.
Drain the oil from the rear axle. remove the PTO shaft, remove the drawbar, remove the bolts from the large plate on the bottom of the rear axle, (this has dowels so it might be tight) and remove the pump. When you dismantle the pump, mark all the parts so you get them back together in the same place.
The other way is to remove the lift and work from the top to get the pump out.
There is only one pipe from pump to lift and this is pushed in rather than bolted.
Hope this helps.
