Fordson Tractors Discussion Forum
Liner Bottom Seal Groove
Oleblue
04-26-2006 00:45:48
Just replacing liners and noticed section of the top side of the lower seal groove corroded on 2 pots. Keeping fingers crossed the liner will still seal against the block or does it rely on sealing all round the groove?
It was a good snug fit when it went in and the rest of the groove was fine...
Any advice much appreciated
Majorman
04-26-2006 09:23:00
 Re: Liner Bottom Seal Groove in reply to Oleblue, 04-26-2006 00:45:48
If its corroded away it needs urgent attention. If you reassemble like that you will have water in the sump very quickly.
Build the top of the groove up with a Molecular Metal type substance.
