Fordson Tractors Discussion Forum
Re: Major regulator testing........
Majorman
04-11-2006 10:47:01
Your dynamo should be giving you an output of 14 to 15V. The easiest way to test is to put a voltmeter across your battery and register the voltage when the engine is running at about 1500rpm. It should be as above.
It would depend on what electrical equipment you have if you want to set the regulator. It is not the sort of thing I would recommend you attempting. It is too easy to wreck the dynamo, regulator and battery if you make an error.
