Fordson Tractors Discussion Forum
Gearbox oil-20W/30 H.D or equivalent
Neil Paisnel
03-21-2006 00:19:43
Have just been looking throught the Dexta manual, and came across the oil spec required for the rear axle/hydraulics and gearbox.
The spec says 20W/30 H.D. What does the HD refer to?
I have always used the usual Super universal, but was recently advised that a much heavier 80 or 90 grade EP oil would be OK for the gearbox. Hence the reason for looking in the manual, .
Anyone any experience with putting a thicker grade EP oil in Dexta gearboxes?
Kim
03-21-2006 12:17:18
 Re: Gearbox oil-20W/30 H.D or equivalent in reply to Neil Paisnel, 03-21-2006 00:19:43
Testing, plese ignore. Trying to get the forum functioning.
Thx
Majorman
03-21-2006 00:32:28
Oil in the gearbox and rear axle should be 30W. The HD just refers to the old oil specification for diesel engines. This was so you could use the same oil in all the parts of the tractor but any 30W will be OK.
I would not use heavy oil in the gearbox. Dextas tend to wear the gear lever and whilst this is not a major problem, heavy oil may put a greater load on the lever when moving between gears.
I would definitely not use heavy oil in the rear axle/hydraulics. I have seen so many problems caused by this in cold weather.
Neil Paisnel
03-21-2006 04:30:04
 Re: Gearbox oil-20W/30 H.D or equivalent in reply to Majorman, 03-21-2006 00:32:28
Understand about the rear axle, as that is also hydraulic feed.
Thanks for the HD info though.
I have just re built the gearbox, and have welded 'ears' on the selector shaft fittings (the bits the levers locate into. Hopefully this will stop the levers jumping out of the selector shaft if it is not moved exactly straight.
Cheers
Neil
