Fordson Tractors Discussion Forum
64 oil in exhaust
dwol
01-26-2006 15:09:24
On my FSMD I am getting some oil out the exhaust pipe. It kinda drips out a little here and there and makes a mess. Any Ideas on what it causing this? Thanks in adavance.
Majorman
01-26-2006 23:16:51
 Re: 64 oil in exhaust in reply to dwol, 01-26-2006 15:09:24
Simply not enough hard work.
This will be a common problem with all underworked diesel engines. To get the best from them they need to be either hard at work or stopped.
The cure would be a couple of days on the plough working at about 1600 rpm.
dwol
01-27-2006 13:51:24
 Re: 64 oil in exhaust in reply to Majorman, 01-26-2006 23:16:51
Thanks, That I can fix. I have about 2 or three more months untill I need to disc and I will be putting in some long hours then. I will be pulling a pretty decent size disc and she should warm up pretty good.
Just for my own knowledge, what is the condition that causes this?
Majorman
01-28-2006 00:08:43
 Re: 64 oil in exhaust in reply to dwol, 01-27-2006 13:51:24
Softening and washing away of the carbon seal around the top of the piston.
If you strip a diesel that has been on light loads, the carbon is so soft it will wipe off. A hard working engine will have carbon so hard you will have to scrape it off.
