Thanks for the info majorman. My 1963 SM should have the Dual Clutch. lever for Low and high is as you specify. Low is down and high is up. I have tried to adjust the linkage but the first pressure is not working. In order to change gears I have to depress the clutch until the PTO stops. there is no bolt at the bottom of the clutch pedal which would prevent it from going through its full travel. The only othr recourse would be to split the tractor to see what the problem is. I am assuming I have a dual clutch. It could be a situation of a previous owner putting a single clutch system in it, as I understand the dual clutch is quite expensive to repair. Tractor works fine and its just a bit of a nuisance not having hydraulics when the clutch is depressed. I am learning to think ahead when operating the blade to move snow. So in a nutshell, I will just live with it. Thanks again, Kenneth
