Fordson Tractors Discussion Forum
more disc brake problems
nelson from new
12-13-2005 01:09:46
I pulled the brakes and linkages apart on my super major to free up from rust ect, reassembled and took tractor for a run about a km down the road the left hand brake began to grab and by the time I got back home you could cook a steak on the housing! what have I done.
dwol
12-13-2005 08:54:20
 Re: more disc brake problems in reply to nelson from new zealand, 12-13-2005 01:09:46
I had the same experiance on my 64. Only the left side seemed to grab. I loosened everything up and took it out and drove for a while. It heated up enough to melt my shoe. Then I let her cool, and ever since It has been fine. Never opened it back up since the first time.
Majorman
12-13-2005 03:55:02
You probably set it too tight.
Did you reset by slackening the adjuster lock nut, tightening the screw until the brake locked then back 1.5 turns?
Or did you adjust using the pull rod nut in the linkage? This is only to set a pedal clearance of 1.5" and is not the brake adjuster.
Trevor C
12-13-2005 06:55:11
 Re: more disc brake problems in reply to Majorman, 12-13-2005 03:55:02
Every thing has been dismantled and both oil seals replaced on the pinion shafts so the adjuster and pull rods have been removed or slackened. With the brake housing sitting on the bench and the discs and actuating plates laid inside they are approximately 1.5 mm beyond the housing. I have solved problem by hand cutting a 3 mm gasket for the face plate which I’ll remove as the disc wear.
Thanks for the help.
TC.
Majorman
12-13-2005 09:14:54
 Re: more disc brake problems in reply to Trevor C, 12-13-2005 06:55:11
I don't like the sound of a gasket between the brake housing and face plate. In event of the brakes overheating this could break down and leave the face plate loose causing all the bolts to shear and you with no brakes. As I replied above, did you set the screw adjuster underneath fully back before installing the discs. This can cause the problem you have with the liners. Also, wrong liners could be the cause. I have had to sand down liners to get them to fit before now.
