Fordson Tractors Discussion Forum
Ford Dexta - Fair value
Steven Cossette
11-04-2005 03:35:06
Please give me your thoughts on the value. The tractor starts, runs, drives, the three point goes up and down nicely, there doesn't appear to be any dripping leaks, it's been repainted and some of the top coat is peeling, the metal isn't rusted, the tires are weathered but should last for a while. I didn't get a chance to drive it, but I did make sure all the gears forward and reverse worked. It has some hydraulic couplers going to the rear, but I'm not sure what thats for. Any help would be appreciated! Thanks.
Majorman
11-04-2005 08:24:17
 Re: Ford Dexta - Fair value in reply to Steven Cossette, 11-04-2005 03:35:06
Prices range from Rough £300.00 ($504) to Excellent £2000.00 ($3360.00). Some specials have made £25,000.00 ($42,000.00) over here at sales.
Jerry Coles
11-18-2005 12:44:48
 Re: Ford Dexta - Fair value in reply to Majorman, 11-04-2005 08:24:17
You say there is a couple of Hydraulic couplingss at the rear. If you have two pipes to the rear and the hydraulic lever goes from centre position forward and also backwards then you have the Double Acting Ram valve option [push/pull] which is more versatile than the single valve (one pipe [Push and drain by weight]). These are a fairly rare option. I'm looking for one here in the UK.
Good luck!
