Fordson Tractors Discussion Forum
Dexta engine-hunting at idle
Steven Cossette
11-03-2005 05:04:48
I'm still interested in this Dexta coming up for auction. Majorman has informed me that this tractor should be OK to run a rototiller. My next question is; when I checked the tractor over, when the engine started, it hunted up and down. The owner said it does this when cold, but will quit when warm. I will have to take his word because I couldn't run it much. Is this something that I should be conserned about, or maybe a easy adjustment on the inj. pump? Thanks!
Majorman
11-03-2005 07:02:49
 Re: Dexta engine-hunting at idle in reply to Steven Cossette, 11-03-2005 05:04:48
Most Dexta's tend to hunt with the vaccum governed pump. It is not a problem unless it gets very bad at all revs, then it is cured by changing the rubber diaphram in the pump. This can be a bit pricey but diaphrams are about at reasonable costs and they are quite easy to fit.
