Fordson Tractors Discussion Forum
Fordson Super Major: Hydraulics
JPS
10-24-2005 00:28:12
I reecently purchased a Fordson Super Major. The three point hitch hydraulics do not work. Also, the hydraulic outlets for use with implement hydraulic cylinders do not work. Information regarding the non-functioning of the Fordson Super Majors hydraulics will be appreciated. Information from, and sources of, Fordson Super Major Service Manuals will also be appreciated.
John (JPS)
Majorman
10-24-2005 22:49:59
 Re: Fordson Super Major: Hydraulics in reply to JPS, 10-24-2005 00:28:12
Make sure the PTO is in gear before trying the hydraulics. If this does not cure the problem, the lift will have to come off as you are most likely to have a stuck unload valve. Try Link fordson.freeweb/nl, there is a lot of information on how to do it in the posts there.
