Fordson Tractors Discussion Forum
54 Major spindle bushings
David Lewis
09-29-2005 17:09:36
I have very well worn spindles and bushings in the front axle and will replace them, but can only get upper bushings. Could it be that they are the same specs as lower bushings, so I can use upper bushings at top and bottom of spindle. From the diagram, it looks as if the might be identical..... ....
Loren Tolkkinen
10-08-2005 10:00:49
 Re: 54 Major spindle bushings in reply to David Lewis, 09-29-2005 17:09:36
Dave- I also need to replace bushings and I am wondering where you found them. Also, were you able to find a replacement spindle? Loren
RKM
10-01-2005 04:47:00
The upper bushings will work fine in the bottom. The dimensions are the same. There is only a small difference in the grease groove, but it doesn't affect them. No matter what bushings you use, they will need to be reamed or honed after installation to fit the spindles.
