Fordson Tractors Discussion Forum
Re: help! need info on our 1955 fordson major die
Stevo
08-17-2005 17:44:37
I have an E27N Fordson tractor which has a perkins diesal engine, when I got it it had a collapsed bull pinion shaft bearing which caused the LHS wheel to lock, I"m unsure if yours is similar. If in front of the axle you have a brake drum then this may be the culprit. To check you"ll beed to remove the brakes and have a look inside, the bearing is quite large and easilly seen, if its in pieces, not here at all or missing any balls then this could be the problem. Also are you sure the clutch is engaging? ie is it trying to drive but jamming or is the back wheel fully locked?
Regards,
Stevo
