Fordson Tractors Discussion Forum
Fordson Super Major Sump Removal
motoboy
08-09-2005 16:47:14
In the process of removing the engine oil sump
(oil pan) and was wondering if there are any bolts under the front plate? Or if the only ones are the ones on the sides and at the tranmission assy?
Thanks
Mark
Majorman
08-10-2005 00:01:13
 Re: Fordson Super Major Sump Removal in reply to motoboy, 08-09-2005 16:47:14
Don't forget the ones that go from front to back under the side frames to the transmission housing and one up a shaped area at the front of the sump. Thats all there is.
OLEBLUE
03-10-2006 01:35:23
 Re: Fordson Super Major Sump Removal in reply to Majorman, 08-10-2005 00:01:13
I am in the process of removing a super major sump have removed all the bolts I can see front axle side frames one arkward one across the front but so far we have barely managed to crack the paint. Was considering a drop of petrol and a match.... there arent any dowels or anything are there? Also found the front hole for the A frame pin in the sump was cracked... Will persevere but any ideas much appreciated....
