Fordson Tractors Discussion Forum
Simms injection pump lubrication
kkkk
08-04-2005 15:24:47
I have the vacuum governed Simms injection pump in my Diesel Major. Do I need to put oil in it or does it lubricate itself with the fuel? How do I put the oil in it and how much? The pump has not been used for quite a while so it must be dry.
ron algiere
08-04-2005 17:23:22
 Re: Simms injection pump lubrication in reply to kkkk, 08-04-2005 15:24:47
no need for oil, the fuel takes care of it, if the pump is that dry, release the compression arm, bleed the system nad crank at 15 second intervals so you don't tax the starter, that should be enough to get some fuel in the case
