Fordson Tractors Discussion Forum
Re: Major water pump and thermostat
Majorman
07-30-2005 00:50:30
Quote from the Fordson Workshop manual published by Ford in 1963: "At engine number 1425097 changes were made to the water ports in the pump body and it is essential that pump bodies and assemblies for tractors prior to that engine number are not used on later tractors. It is important that the correct gasket is used as the location of the ports is different on previous and current parts".
In the Ford parts book two different water pumps are listed so there is no interchangeability between the two pumps.
The later thermostats can be used in both but the earlier 'stat should not be used in the later engine.
Timo Haveri
07-31-2005 11:31:46
 Re: Major water pump and thermostat in reply to Majorman, 07-30-2005 00:50:30
Thanks for the answer, Majorman. I"ll just have to ask some other patrs dealer for the pump. But how about the thermostat? The one I bought is not either one of the correct types but a common automotive type. The only similarity to the thermostats pictured in the manual is the temperature value (74 deg Celsius).
So, I have understood that since I have the earlier type tractor there is no need of shroud or anything. The earlier thermostat is not meant to open or close any by-pass ports. Is this correct? But for the later type tractor it would be essential to have the correct shrouded thermostat? Again, thank you for the answers in advance.
Majorman
08-01-2005 00:29:37
 Re: Major water pump and thermostat in reply to Timo Haveri, 07-31-2005 11:31:46
Your thermostat will be OK as it is the correct temperature. The shroud did not move, only made the flow of water go around the coils not directly on to them as did the earlier version.
Timo Haveri
08-04-2005 14:53:02
 Re: Major water pump and thermostat in reply to Majorman, 08-01-2005 00:29:37
Thank you very much for the answer, Majorman.
