Dexta leaking induction primer pump
Paul Woodward
01-19-2000 13:32:21
Does anyone know how to dismantle, reseal and reassemble a leaking induction primer pump? It is an integrated unit with the fuel tap.I should be grateful to receive as much detail as possible as I can,t see a way into it at the moment.Thanks.
Burrhead
01-29-2000 12:10:35
 Re: dexta leaking induction primer pump in reply to Paul Woodward, 01-19-2000 13:32:21
I was unable to find a new cap for mine so I added an electric pump up underneath so it won't be seen. If you are able to find a new cap&pump you will be doing alots better than I did.
moscratch
05-24-2005 01:10:58
 Re: Re: dexta leaking induction primer pump in reply to Burrhead, 01-29-2000 12:10:35
You can get a new primer pump from>Link
A>Link bit pricy though!
Mine is missing this part and not starting too quickly... Does the cold start work much better with this fitted or should I modify to the system on (for example) a 35?
