Fordson Tractors Discussion Forum
Model F valves
Larrrry
05-09-2005 19:06:59
Hello;
I unstuck my fordson (it sat many years).
I need to do a valve job (rust). Where can I get
valves and guides? Most of the valves are knife
edge and 2 have to much of the stem rusted away to
reuse. Did anyone make adjustable lifters? If I
install new valves, I would need to grind a lot
off the stem to get the clearance of .020 . Can a valve seat replacement be obtained and machined
in. Does anyone have several used valves I could
buy instead of running a new valve by grinding it
to fit?
Thank you Larry
