Fordson Tractors Discussion Forum
super dexta steering
Skog
03-29-2005 06:05:53
Can anyone give me some advice on removing the steering wheel from my super dexta. I seems to be well and truly seized on, unless I"m not using the right technique. Is it on a splined shaft? Does it need a puller to remove it?
Many thanks for any suggestions.
degerb
03-29-2005 08:12:04
 Re: super dexta steering in reply to Skog, 03-29-2005 06:05:53
I had the same problem with my S/D. I tried everything.. heat, solvent, even hyd. fluid. I finally tried a bearing removal tool from a mail order catalog. It worked fine but it was kind of hard on the underside of the steering wheel. The wheel does have fine splines. Good luck!
Skog
03-29-2005 10:12:01
 Re: super dexta steering in reply to degerb, 03-29-2005 08:12:04
Thanks very much for that, I feared there may not be an easy solution!
