Fordson Tractors Discussion Forum
Oil in radiator
Richard in Pa.
03-26-2005 18:30:07
Motor oil in radiator and coolant. Some advice was to check the headgasket. I pulled it apart but the headgasket doesnt look blown. Is this something you can see with the naked eye? What is the problem? Sure could use you experts to help !! Anyone close to northeast pa. ? HELP!
Majorman
03-27-2005 00:17:48
 Re: Oil in radiator in reply to Richard in Pa., 03-26-2005 18:30:07
Sometimes it is hard to see as it is leaking between the oil galleries and the water galleries and does not get burnt as it would between cylinders. I would check the liner height ( to 4 thousands of an inch) and refit with a new gasket. Torgue down to 90 ft/lbs.
Richard in Pa.
03-27-2005 08:06:33
 Re: Oil in radiator in reply to Majorman, 03-27-2005 00:17:48
Thanks Majorman ! Its my first farm tractor, and I love it. Alot easier to work on than a car !
