Fordson Tractors Discussion Forum
Forson Super Dexta Steering
meathman
01-02-2005 11:47:09
Hi all
Anyone out there ever done any work on the steering box of a Super Dexta...
Two things I have a problem with
1. The top bearing is bad and the steering wheel is loose...is this hard to rectify and can it be done without removing the box.
2. There is a lot of "free play" in the box can I get at the shims to remove one from the plate on the lhs of the lower part of the box.
Thanks guys in advance
mwo
01-05-2005 06:49:01
 Re: Forson Super Dexta Steering in reply to meathman, 01-02-2005 11:47:09
You should be able to buy the top ball bearing at your New Holland dealer. The shims on the outside can be taken out. You may need to replace the lower seals if you are going to fill the steering column with oil. I still have 2 that I didn't use.
meathman
01-06-2005 08:26:41
 Re: Forson Super Dexta Steering in reply to mwo, 01-05-2005 06:49:01
Thanks for your help I hope to get at the job on this Saturday coming, so I"ll keep u posted on how I get on..
BTW would it be easier to remove the box from the tractor first to work on it?
Thanks
