That sounds good, Mark. I'm too old (63) to do much skiing, and I never learned anyway. It'd be great to have you come by on your way. We're 40 miles from Bend here and get down there quite often. I've been to Mt. Bachelor one time, with the intention of eating at the mountaintop restaurant. A thunderstorm closed it down that day so I never got up there. Other than the accelerator problem already identified, I'd like you to look at the engine and give me your thoughts as to where I am leaking oil. The engine has the usual number of drips and leaks, mostly fuel at the sediment bowl and a slow lead somewhere in the fuel tank, maybe up inside where the steering column comes through. The other leak that concerns me more than fuel is one that occurs when the engine is running. I notice that after every use the front axle and front wheel/tire (right side) are spattered with fine drops of black oil, and that the front underside of the engine drips a few drops of engine oil when I shut it off. Then it stops dripping until I fire it back up again. Ron, if you read this, I used to live in upstate New York. I was pastor of a church in Delhi, near Oneonta. Are you in the Catskills, Finger Lakes region, or the Adirondacks? I love New York (the state, that is).
