Fordson Tractors Discussion Forum
What year is this tractor?
ORiley
09-23-2004 05:13:29
All,
What year was this tractor made?
The number by the starter is:271726.
The number under the seat is: K27B.
Any help would be helpful.
Thanks
Majorman
09-23-2004 23:53:37
 Re: What year is this tractor? in reply to ORiley, 09-23-2004 05:13:29
Date code on lift gives August 27th 1958. Other date codes on the tractor would help to confirm this.
Serial number is most likely an export one or engine could have been replaced with an industrial unit. It looks like an Australian number but only my opinion.
Maine Fordson Operator
09-23-2004 10:58:29
If it's a Fordson Model F (steel wheels), it should be a 1923.
David Flusche
10-14-2004 03:42:42
 Re: What year is this tractor? in reply to Maine Fordson Operator, 09-23-2004 10:58:29
where is the serial number stamped on a 1920's fordson tractor? i cant find it on my tractor.
ORiley
09-23-2004 12:12:29
I was told it was 1958 to 1961 Fordson Power Major
Where should I look for numbers Thanks for the help
ORiley
09-23-2004 16:18:42
 Re: What year is this tractor? in reply to ORiley, 09-23-2004 12:12:29
Jeez, I should have been paying attention! The Model F didn't even *have* a starter, unless that's what you want to call the crank! I gotta stop reading these boards so late at night...
I don't know much about the Power Major series, but if you can find a serial number on the engine somewhere, there is a menu on the left of this page called "Research & Info". Go there, and then click on "Serial Numbers" and follow the menus to the section on the Power Majors.
The serial number should be seven digits, ranging anywhere from 148NNNN through 16NNNNN .
Hope this helps.
