Order Ford 801 Parts Online
1959 801sos
dodgecbr
01-31-2008 03:41:04
i am trying to figure out what the part is below the battery. looks like a knob some attachment fits on. the other side doesnt have one or has been taking off. i posted a pic under the gallery help identify. it is smudged around the part to locate it.
dodgecbr
01-31-2008 12:40:07
 Re: 1959 801sos in reply to dodgecbr, 01-31-2008 03:41:04
yeah its on ebay i couldnt figure out what it was. what do yall think about the starting bid price? i thought it was kinda high it not running and having the sos tranny.
Larry NCKS
01-31-2008 11:46:11
that air cleaner is standard equipment on the diesel priors. I have two 4 cyl 4000 diesels with that air cleaner.
souNdguy
01-31-2008 07:52:56
Ya wanna sell that loader bracket?
Check under the front axle /kingpin flange for another bracket.
Soundguy
Fordfarmer
01-31-2008 08:58:53
 Re: 1959 801sos in reply to souNdguy, 01-31-2008 07:52:56
This tractor is on ebay... and it does have the front bracket, but not sure about the flat one under the belly.
Pernell
01-31-2008 06:55:10
Rear mount for 1 arm bandit loader.
Larry NCKS
01-31-2008 05:35:20
 Re: 1959 801sos in reply to Larry NCKS, 01-31-2008 03:41:04
Yep! I agree. By the time I get that pic blpwn up enough to see what you're talking about . . . it's too fuzzy to see it. I will guarantee it does not have anything to do with the throttle, however.
I am wondering, though, if someone didn't change out the air cleaner. I thought all the diesel 01s had the box below the manifold. You have the early thousand style ststem on yours. If that's the case, what you're looking at could have been a hanger for the early air intake system.
KCM
01-31-2008 09:42:57
 Re: 1959 801sos in reply to Larry NCKS, 01-31-2008 05:35:20
Isn't that air cleaner a dealer accessory? I have seen that style on other Fords.
murn ga
01-31-2008 05:35:33
That's the top mount for the one arm loader.The loader slides on this knob and put a pin thru it to keep it on.
Joe(TX)
01-31-2008 04:58:51
You need a closer shot.
Dave from Texas
01-31-2008 04:36:36
You may be talking about the throtle disc. Rods connect to the carb and to the hand leaver.
